compiiler error for warpxxx example of xfopencv
Dear,
no matter to define _XF_SYNTHESIS_  1 or 0, it always show below error messge, please help, thank you.
CRITICAL WARNING: [SYNCHK 200-61] warpperspective/imgproc/xf_warpperspective.hpp:1146: unsupported memory access on variable 'transformation_matrix' which is (or contains) an array with unknown size at compile time.
CRITICAL WARNING: [SYNCHK 200-22] warpperspective/common/xf_utility.h:369: memory copy is not supported unless used on bus interface possible cause(s): non-static/non-constant local array with initialization).
WARNING: [SYNCHK 200-23] warpperspective/imgproc/xf_warpperspective.hpp:116: variable-indexed range selection may cause suboptimal QoR.
WARNING: [SYNCHK 200-77] The top function 'perspective_accel' (warpperspective/xf_warpperspective_accel.cpp:33) has no outputs. Possible cause(s) are: (1) Output parameters are passed by value; (2) intended outputs (parameters or global variables) are never written; (3) there are infinite loops.
Re: compiiler error for warpxxx example of xfopencv
No, the projecr had been closed by no any reply. Thanks for asking.
Did you program also FPGA?
Sorry, my issue is compiler error, so I could not program FPGA before compiler pass.
But for other examples (like accumulate, remap...) of xfopencv, I did it in HLS simulation and work properly.
Did you solve it?
