jiajiahao069
compile vitis libraries L1/remap case error in Vitils hls 2020.2 in windows 10
 I am running the case in vitis hls 2020.2. I tried to run the remap case in L1 folder. copied the attachment(settings.tcl and run_hls.tcl) in vision/L1/remap folder.
 I downloaded the compiled opencv lib from the github. and set the environment.
git clone -b OpenCV-3.4.8-x64 git@github.com:huihut/OpenCV-MinGW-Build.git
need modify the settings.tcl files based on your local opencv libs.
Use the vitis HLS 2020.2 command prompt to create the project.(vitis_hls -f run_hls.tcl)
The following image is the result. I don't know what's the reason. Please try the scripts and help me fix the error.
hemangd
@jiajiahao069
Vitis vision libraries/ the acceleration libraries are not supported in Windows OS. Kindly use Linux OS and check.
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
jiajiahao069
Hi Hemangd,
I don't find the information which doesn't support in Windows OS. Could you post the related information?
And I can run vitis libraries 2019.2 branch in windows 10. It works normally. the vitis tool doesn't include the compiled opencv libs after 2020.1. I think this is the reason about the error.
hemangd
@jiajiahao069
That will be under pipeline with the future releases of the tool.
Xilinx will not provide support if you find issues on Windows OS with Vitis vision libraries/ the acceleration libraries. Hence, kindly use Linux OS.
hemangd
