cosim problem for 2019.2 but not 2018.2
Hello all,
I tried to cosimulte the 2d line buffer example on 2019.2 version and it freezes. however it runs on 2018.2 version. Is this a known problem for the 2019.2 version. Is there anyone who were able to successfully finish cosimulation in 2019.2 version. I tried many examples, but all of them freezes for cosimulation. Also i heard that that 2018.2 has problems with the imread function(which i require). Is there a stable version which doesn't have any problems with cosimulation.
Did you use HLS's GUI for cosim?
Check "Setup Only",  and run cosim, then ./sim/verilog/sim.bat will be generated.
Run this file on terminal, cosim may finish properly.
hello,
Thank you for the reply. i tried your approach. I did setup only and the sim.bat file was generated, However, when I run the sim.bat file its freezing at the same point as it used to. I have attached the image
 did you face this similar problem, is there a way around this}
the options I used for the cosimulation is
 can you please suggest any other steps I can take to run it successfully. I am working with windows version
The options are same with mine, and I also use windows.
But, I did not freeze when using CUI.
I'm sorry I could'nt help you.
No problem, thanks for your suggestions though.
which version of windows were you using?
