12-10-2019 06:17 AM
I'm using vivado HLS 2019.1 and the xfopencv library. I am having problem with the crop() function from this library. The crop accel can't be synthesized. I didn't add any code. I only modifed the config.h with my image size and the ROI regions in the testbench. The accelerator itself is kept the same as in the example code of the library.
The C simulation runs without any problem. I checked the result and it was ok. But C Synthesis ends with abnormal program termination (11). The log file is not helpful, just a long list of *.so files plus some hex numbers. In the GUI i get warnings about "Since the only kind of statements allowed in a dataflow region are variable declarations and function calls, the compiler may not be able to correctly handle the region: </some address>".
Since I used the original code from the example, I think this warning shouldn't be much of a problem. But the synthesis just crashes after the warnings. The last line before the crash is "running pass 'array normalization' on module '/<some address>/a.g.1.bc'."
I don't know what is the problem. Any advice is appreciated.
12-25-2019 03:08 AM
12-14-2019 11:30 PM
Hi @ma.william ,
It's a rarely occurred problem. Issues like this are difficult to determine without the design.
open an SR and provide the design with Xilinx If you have the rights to.
**~ Got a minute? Answer our Vitis HLS survey here! ~**
12-25-2019 03:08 AM
