Visitor gknowles
dataflow and loops in HLS
I am having a problem with a systolic array design in HLS. I want to use the
dataflow directive to generate no_proc-1 copies of pe_wrapper. However,
(looking at the VHDL) it only generates 1 copy and muxes all the signals into that.
The output of synthesis is:
INFO: [HLS 200-10] Checking synthesizability ...
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper' (pe_array.c:303) automatically.
INFO: [HLS 200-111] Finished Checking Synthesizability Time (s): cpu = 00:00:03 ; elapsed = 00:00:02 . Memory (MB): peak = 348.473 ; gain = 12.602 ; free physical = 22980 ; free virtual = 68436
INFO: [XFORM 203-721] Changing loop 'Loop_1_proc' (pe_array.c:341) to a process function for dataflow in function 'all_pe_loop_wrapper'.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'Loop_1_proc' (pe_array.c:335:64), otherwise it may not be synthesized correctly.
INFO: [XFORM 203-712] Applying dataflow to function 'all_pe_loop_wrapper' (pe_array.c:328), detected/extracted 1 process function(s):
'Loop_1_proc'.
INFO: [HLS 200-111] Finished Pre-synthesis Time (s): cpu = 00:00:03 ; elapsed = 00:00:02 . Memory (MB): peak = 476.453 ; gain = 140.582 ; free physical = 22960 ; free virtual = 68416
INFO: [HLS 200-111] Finished Architecture Synthesis Time (s): cpu = 00:00:03 ; elapsed = 00:00:02 . Memory (MB): peak = 476.453 ; gain = 140.582 ; free physical = 22952 ; free virtual = 68407
INFO: [HLS 200-10] Starting hardware synthesis ...
INFO: [HLS 200-10] Synthesizing 'all_pe_loop_wrapper' ...
INFO: [HLS 200-10] ----------------------------------------------------------------
INFO: [HLS 200-42] -- Implementing module 'pe_wrapper'
INFO: [SCHED 204-11] Starting scheduling ...
INFO: [SCHED 204-11] Finished scheduling.
INFO: [HLS 200-111] Elapsed time: 1.92 seconds; current allocated memory: 78.235 MB.
INFO: [BIND 205-100] Starting micro-architecture generation ...
INFO: [BIND 205-101] Performing variable lifetime analysis.
INFO: [BIND 205-101] Exploring resource sharing.
INFO: [BIND 205-101] Binding ...
INFO: [BIND 205-100] Finished micro-architecture generation.
INFO: [HLS 200-111] Elapsed time: 0.02 seconds; current allocated memory: 78.387 MB.
INFO: [HLS 200-42] -- Implementing module 'Loop_1_proc'
INFO: [HLS 200-111] Elapsed time: 0.04 seconds; current allocated memory: 78.674 MB.
INFO: [HLS 200-111] Elapsed time: 0.02 seconds; current allocated memory: 78.838 MB.
INFO: [HLS 200-42] -- Implementing module 'all_pe_loop_wrapper'
INFO: [HLS 200-111] Elapsed time: 0.04 seconds; current allocated memory: 78.933 MB.
INFO: [HLS 200-111] Elapsed time: 0.02 seconds; current allocated memory: 78.978 MB.
INFO: [HLS 200-10] -- Generating RTL for module 'pe_wrapper'
INFO: [RTGEN 206-100] Finished creating RTL model for 'pe_wrapper'.
INFO: [HLS 200-111] Elapsed time: 0.04 seconds; current allocated memory: 79.223 MB.
INFO: [HLS 200-10] -- Generating RTL for module 'Loop_1_proc'
INFO: [SYN 201-210] Renamed object name 'Loop_1_proc_diagonal' to 'Loop_1_proc_diagobkb' due to the length limit 20
INFO: [RTGEN 206-100] Finished creating RTL model for 'Loop_1_proc'.
INFO: [HLS 200-111] Elapsed time: 0.06 seconds; current allocated memory: 80.113 MB.
INFO: [HLS 200-10] -- Generating RTL for module 'all_pe_loop_wrapper'
INFO: [RTGEN 206-500] Setting interface mode on port 'all_pe_loop_wrapper/delay_reset' to 'ap_memory'.
INFO: [RTGEN 206-500] Setting interface mode on port 'all_pe_loop_wrapper/query_vec' to 'ap_memory'.
INFO: [RTGEN 206-500] Setting interface mode on port 'all_pe_loop_wrapper/subject_vec' to 'ap_memory'.
INFO: [RTGEN 206-500] Setting interface mode on port 'all_pe_loop_wrapper/traceback' to 'ap_memory'.
INFO: [RTGEN 206-500] Setting interface mode on port 'all_pe_loop_wrapper/h' to 'ap_memory'.
INFO: [RTGEN 206-500] Setting interface mode on function 'all_pe_loop_wrapper' to 'ap_ctrl_hs'.
Any ideas?
void all_pe_loop_wrapper( bool delay_reset[no_proc+1], unsigned char query_vec[no_proc], unsigned char subject_vec[no_proc], unsigned char traceback[no_proc], signed short h[no_proc] ) { signed short diagonal[no_proc+1]; signed short left[no_proc+1]; signed short eleft[no_proc+1]; #pragma HLS dataflow #pragma HLS unroll for(int i = 1; i < no_proc; i++) { pe_wrapper(delay_reset[i+1],delay_reset[i+1], query_vec[i],subject_vec[i],diagonal[i],left[i],eleft[i],OPEN_DEL + i*EXTEND_DEL,OPEN_DEL + (i-1)*EXTEND_DEL, &diagonal[i+1],&left[i+1],&eleft[i+1],&traceback[i],&h[i]); } }
Scholar u4223374
Re: dataflow and loops in HLS
The "unroll" pragma needs to be inside the loop. You can use the "allocation" pragma to tell HLS to build lots of copies of a function, so that might be worth a try too.
Visitor gknowles
HI
Moving the #pragma HLS unroll into the loop works, it looks like it now generates the no_proc-1 copies. However, it complains
about the query_vec/subject_vec etc being connected to multiple processes.  Doesn't it understand these are vectors?
Here is the synthesis ouput with no_proc = 10:
INFO: [HLS 200-111] Finished Checking Synthesizability Time (s): cpu = 00:00:03 ; elapsed = 00:00:02 . Memory (MB): peak = 348.473 ; gain = 12.602 ; free physical = 24833 ; free virtual = 69310
INFO: [XFORM 203-501] Unrolling loop 'Loop-1' (pe_array.c:340) in function 'all_pe_loop_wrapper' completely.
INFO: [XFORM 203-102] Partitioning array 'diagonal' (pe_array.c:335) automatically.
INFO: [XFORM 203-102] Partitioning array 'left' (pe_array.c:336) automatically.
INFO: [XFORM 203-102] Partitioning array 'eleft' (pe_array.c:337) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper8' (pe_array.c:303) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper9' (pe_array.c:303) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper10' (pe_array.c:303) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper11' (pe_array.c:303) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper12' (pe_array.c:303) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper13' (pe_array.c:303) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper14' (pe_array.c:303) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper15' (pe_array.c:303) automatically.
INFO: [XFORM 203-602] Inlining function 'pe' into 'pe_wrapper16' (pe_array.c:303) automatically.
ERROR: [XFORM 203-711] Array 'query_vec' (pe_array.c:329) failed dataflow checking: it can only be connected at most 2 processes.
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl69_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl6971_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl6973_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl6976_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl6979_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl6982_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl6985_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl6988_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'query_vec' has read operations in process function 'Block_codeRepl6991_proc' (pe_array.c:342:2).
ERROR: [XFORM 203-711] Array 'subject_vec' (pe_array.c:330) failed dataflow checking: it can only be connected at most 2 processes.
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl69_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl6971_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl6973_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl6976_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl6979_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl6982_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl6985_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl6988_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'subject_vec' has read operations in process function 'Block_codeRepl6991_proc' (pe_array.c:342:2).
ERROR: [XFORM 203-711] Argument 'h' (pe_array.c:332) failed dataflow checking: it can only be written in one process function.
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper8' (pe_array.c:226:2).
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper9' (pe_array.c:207:2).
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper10' (pe_array.c:207:2).
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper11' (pe_array.c:207:2).
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper12' (pe_array.c:207:2).
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper13' (pe_array.c:207:2).
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper14' (pe_array.c:207:2).
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper15' (pe_array.c:207:2).
WARNING: [XFORM 203-713] Argument 'h' has write operations in process function 'pe_wrapper16' (pe_array.c:207:2).
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper8' (pe_array.c:226:2), otherwise it may not be synthesized correctly.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper9' (pe_array.c:207:2), otherwise it may not be synthesized correctly.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper10' (pe_array.c:207:2), otherwise it may not be synthesized correctly.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper11' (pe_array.c:207:2), otherwise it may not be synthesized correctly.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper12' (pe_array.c:207:2), otherwise it may not be synthesized correctly.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper13' (pe_array.c:207:2), otherwise it may not be synthesized correctly.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper14' (pe_array.c:207:2), otherwise it may not be synthesized correctly.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper15' (pe_array.c:207:2), otherwise it may not be synthesized correctly.
WARNING: [XFORM 203-713] All the elements of global array 'h' (pe_array.c:332) should be updated in process function 'pe_wrapper16' (pe_array.c:207:2), otherwise it may not be synthesized correctly.
ERROR: [XFORM 203-711] Array 'h' (pe_array.c:332) failed dataflow checking: it can only be connected at most 2 processes.
WARNING: [XFORM 203-713] Reading dataflow channel 'delay_reset' (pe_array.c:328) in the middle of dataflow may stall the dataflow pipeline:
WARNING: [XFORM 203-713] Argument 'delay_reset' has read operations in process function 'Block_codeRepl6971_proc' (pe_array.c:342:2).
ERROR: [XFORM 203-711] Array 'delay_reset' (pe_array.c:328) failed dataflow checking: it can only be connected at most 2 processes.
WARNING: [XFORM 203-713] Argument 'delay_reset' has read operations in process function 'Block_codeRepl6973_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'delay_reset' has read operations in process function 'Block_codeRepl6976_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'delay_reset' has read operations in process function 'Block_codeRepl6979_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'delay_reset' has read operations in process function 'Block_codeRepl6982_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'delay_reset' has read operations in process function 'Block_codeRepl6985_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'delay_reset' has read operations in process function 'Block_codeRepl6988_proc' (pe_array.c:342:2).
WARNING: [XFORM 203-713] Argument 'delay_reset' has read operations in process function 'Block_codeRepl6991_proc' (pe_array.c:342:2).
ERROR: [HLS 200-70] Pre-synthesis failed.
