design viewer absent
Hey guys,
I recently installed the xilinx vivado system edition on 30 day evaluation. The design viewer option of Vivado_HLS seems to be missing from my tools pane and also from the solution menu.Can anyone help me out with this issue because the design viewer is majorly used for design optimization which i am unable to do.
Any help would be largely appreciated. I am attaching a screenshot of my GUI.
Starting from 2013.1, design viewer is no longer existed. You may analyze your design in Analysis Perspective instead.
Refer to UG871 for guidance of design analysis.
brucey
brucey
Is there an option to view the control flow graph of the RTL like in design viewer in Analysis Perspective?
It's orgnized in timeline. So, it's much like dataflow in each cycle, and control condition is checked in some cycles.
brucey
ok..thanks..:)
