error: 'AXI_STREAM_IN' was not declared in this scope
when i use vivado hls(2016.2) to run c simulation, The following error occurred:
../../../../top.h:10:53: error: 'AXI_STREAM_IN' was not declared in this scope
../../../../top.h:10:53: error: template argument 4 is invalid
../../../../top.h:10:21: error: template argument 1 is invalid
../../../../top.h:10:14: warning: 'typedef' was ignored in this declaration [enabled by default]
../../../../top.h:11:53: error: 'AXI_STREAM_OUT' was not declared in this scope
../../../../top.h:11:53: error: template argument 4 is invalid
../../../../top.h:11:21: error: template argument 1 is invalid
../../../../top.h:11:14: warning: 'typedef' was ignored in this declaration [enabled by default]
../../../../top.h:14:16: error: variable or field 'hls_sobel' declared void
../../../../top.h:14:16: error: 'AXI_STREAM_IN' was not declared in this scope
../../../../top.h:14:32: error: 'src_axi' was not declared in this scope
../../../../top.h:14:41: error: 'AXI_STREAM_OUT' was not declared in this scope
../../../../top.h:14:58: error: 'dst_axi' was not declared in this scope
../../../../top.h:14:67: error: expected primary-expression before 'int'
../../../../top.h:14:77: error: expected primary-expression before 'int'
The top.h file is as follow:
#ifndef _TOP_H_
#define _TOP_H_
#include"hls_video.h"
#define MAX_WIDTH 1920
#define MAX_HEIGHT 1080
#define INPUT_IMAGE "test_1080p.bmp"
#define OUTPUT_IMAGE "result_1080p.bmp"
typedef hls::stream<ap_axiu<24,1,1,1>> AXI_STREAM_IN;
typedef hls::stream<ap_axiu<24,1,1,1>> AXI_STREAM_OUT;
typedef hls::Mat<MAX_HEIGHT,MAX_WIDTH, HLS_8UC3> RGB_IMAGE;
void hls_sobel(AXI_STREAM_IN & src_axi, AXI_STREAM_OUT & dst_axi, int rows, int cols);
#endif
Does anyone know what is the cause of the error?
@avcon_lee
change this (and similar lines) to:
typedef hls::stream< ap_axiu< 24,1,1,1 > > AXI_STREAM_IN; // note the added spaces.
@avcon_lee
Thanks for your answer.
I encountered the same error and your notice helped me
