Visitor mouhamedmbr
error: expected ',' or '...' before 'predict_label1'
hello ,i 'm trying to compile my c code .i use the exemple of multiplication ,
in the exemple of multiplication we have 2 input an a output
void matrix_multiply_ref(T a[DIM][DIM], T b[DIM][DIM], T out[DIM][DIM])
in my code i have 1 input and 3 output . when i compile my code i have this error "../../../../src/main.cpp:94:44: error: expected ',' or '...' before 'predict_label1'"
this is my code :
template <typename T, int DIM>
void testtestphase_hw(T l[DIM][DIM], T out predict_label1 [DIM][DIM], T out precision1[DIM][DIM],T out prob_estimates_t1[DIM][DIM])
#pragma HLS INLINE off
#pragma HLS array_partition variable=a block factor=FACTOR dim=2
#pragma HLS array_partition variable=b block factor=FACTOR dim=1
	// matrix
	for (int il = 0; il < DIM; ++il)
		for (int jl = 0; jl < DIM; ++jl)
#pragma HLS PIPELINE II=1
			T out[ predict_label1[DIM][DIM], precision1[DIM][DIM],prob_estimates_t1[DIM][DIM]]=[ predict_label1[DIM][DIM], precision1[DIM][DIM],prob_estimates_t1[DIM][DIM]]
		return;
Re: error: expected ',' or '...' before 'predict_label1'
It looks like the solution is in the first error message, which explains clearly where is  the problem. There is a ' ' (blank) in between of 'out' and 'predict_label1'
Did you forget an underscore ?
The same applies for the following arguments.
Scholar u4223374
The problem is evidently this line:
I don't know what you're trying to do here. It's not valid C (because C does not do "[a,b,c]" style formatting), and even if it was valid C it'd just cause a segfault (accessing elements outside the array boundaries).
Visitor mouhamedmbr
i mean for exemple : T out a[DIM][DIM] =a ;
Scholar u4223374
I'm still not sure what you're doing with that line. Are you trying to make a new array that is an exact copy of "a"? If so, that's going to be expensive - it'll have to copy every element individually (ie N² cycles).
The problems I can see here:
(1) "T out a" is not valid. In C, you need "<type> <name>" (eg. "int x" or "float y"). For an array, it'll be that plus square brackets for the dimensions (eg. "int x[123]" or "float y[123][456]"). Assuming that T is a type, "T a" would be acceptable, as would "T a[DIM][DIM]" - but I have no idea what the "out" is doing in there.
(2) Assuming you drop the "out" and just have "T a[DIM][DIM] = a", you've just defined a new variable with the same name as an existing variable. I suspect that the compiler will actually handle this, but it's going to be very confusing.
(3) Changing the name to "b" (ie "T b[DIM][DIM] = a") will not do what you want (at least if my understanding of what you want is correct). C cannot initialize one array from another array (as Matlab would, for example). The only way to achieve that behaviour is to create the new array and then copy each element across (this is what Matlab does, but you don't have to tell it to do that).
