error in generating the m_axi interface
Hi there,
I am creating an m_axi interface for my design which gives out 2d matrix as output.
It will take 2 parameters cos_in and sin_in which i have assigned to s_axilite interface.
I am able to c-simulate and synthesize the design but when i perform c/RTL cosimulation it reports "Fail".
but without the interface its reporting "Pass".
what is wrong with my interface.
(In my design i am using fixed-point data types )
Teacher xilinxacct
Re: error in generating the m_axi interface
@sai_shashi
Not a lot of info to go on, but since you were successful in the synthesis... here is a stab... If the test bench returns a non-zero value, it will report error, even if all else was successful.
Hope that helps
If so, please mark as solution accepted to close the issue. Kudos also welcomed. :-)
