Participant aichamb
g++.exe: error: obj/main.o: No such file or directory
hello,i trying to simulate my code c++ in vivado HLS.i get a lot of problem
ERROR: [APCC 202-3] Gcc Compile failed:
ERROR: [APCC 202-3] Tmp directory is apcc_db
ERROR: [APCC 202-1] APCC failed.
g++.exe: error: obj/svm-predict.o: No such file or directory
g++.exe: error: obj/svm-train.o: No such file or directory
g++.exe: error: obj/svm_model_matlab.o: No such file or directory
g++.exe: error: obj/svmpredict.o: No such file or directory
g++.exe: error: obj/svmtrain.o: No such file or directory
g++.exe: error: obj/yprime.o: No such file or directory
make: *** [csim.exe] Error 1
ERROR: [SIM 211-100] 'csim_design' failed: compilation error(s).
Participant aichamb
Re: g++.exe: error: obj/main.o: No such file or directory
Hello @ hpoetzl,
i fix the majority of errors by installing VS 2017 ,now i have only 2 errors
WARNING: [HLS 200-40] In file included from src/main.c:51:
src/typeinfo.h:28:2: error: This header requires a C++ compiler ...
#error This header requires a C++ compiler ...
src/typeinfo.h:32:10: fatal error: 'typeinfo' file not found
#include <typeinfo>
2 errors generated.
ERROR: [HLS 200-70] Compilation errors found:
Pragma processor failed: In file included from src/main.c:51:
#include <typeinfo>
2 errors generated.
Failed checking during preprocessing.
    while executing
"source C:/Users/aychoucha/Documents/simulate/architechture/solution1/csynth.tcl"
    invoked from within
"hls::main C:/Users/aychoucha/Documents/simulate/architechture/solution1/csynth.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
Voyager
Voyager
Hey @aichamb,
Seems like your compiler failed to compile your sources to object files and what we see here is the linker failing to find those object files for linking them together into the csim.exe.
Check the logs for indications why the compiler failed, here are some potential reasons ...
  • Missing access permissions
  • Not enough disk space
  • Weird network mounts with time differences
  • Problem with the compiler or libraries
Hope that helps,
Herbert
-------------- Yes, I do this for fun!
Participant aichamb
i think the problem from the c++ compiler how can i fix it.
INFO: [HLS 200-10] Running 'd:/Vivado_HLS/2016.4/bin/unwrapped/win64.o/apcc.exe'
INFO: [HLS 200-10] For user 'aychoucha' on host 'desktop-bs3qfva' (Windows NT_amd64 version 6.2) on Sun Oct 29 18:53:47 +0100 2017
INFO: [HLS 200-10] In directory 'C:/Users/aychoucha/Documents/simulate/architechture/solution1/csim/build'
In file included from ../../../../src/main.c:51:
d:/Vivado_HLS/2016.4/win64/tools/clang/bin/../lib/clang/3.1/../../../x86_64-w64-mingw32/include\typeinfo.h:16:2: error: This header requires a C++ compiler ...
d:/Vivado_HLS/2016.4/win64/tools/clang/bin/../lib/clang/3.1/../../../x86_64-w64-mingw32/include\typeinfo.h:19:10: fatal error: 'typeinfo' file not found
#include <typeinfo>
2 errors generated.
   Compiling(apcc) ../../../../src/svm-predict.c in debug mode
INFO: [HLS 200-10] For user 'aychoucha' on host 'desktop-bs3qfva' (Windows NT_amd64 version 6.2) on Sun Oct 29 18:54:01 +0100 2017
apcc_db/svm-predict.c:205:8: error: conflicting types for '__strtod'
d:\vivado_hls\2016.4\msys\bin\../lib/gcc/mingw32/4.6.2/../../../../include/stdlib.h:312:32: note: previous declaration of '__strtod' was here
   Compiling(apcc) ../../../../src/svm-train.c in debug mode
Voyager
Voyager
Hey @aichamb,
It seems like you are including a C++ header in a C file.
Double check that your source file is configured as C++.
Best,
Herbert
Participant aichamb
Hello @ hpoetzl,
#include <typeinfo>
2 errors generated.
#include <typeinfo>
2 errors generated.
    while executing
    invoked from within
    invoked from within
    invoked from within
Voyager
Voyager
Hey @aichamb,
Still looks like you are including C++ header files (directly or indirectly) from a non C++ source file.\
Best,
Herbert
