Visitor nyrn3dlab
hls::Remap
I am currently designing a video processing pipeline and I wanna try the function in the hls library named hls::Remap (as cvRemap).
My problem is that I don't understand why I couldn't use AXI4 Stream to interface map1 and map2. I have an error indicates that AXI stream support only fifo interface and to choose the correct interface for the data channel.
Has anyone an idea how can I solve this problem?
Best regards,
Ny
Re: hls::Remap
For AXI4 stream interface you have to use ap_fifo. Refer to the diagram below.
Debraj
Visitor nyrn3dlab
Re: hls::Remap
Thank you for your reply,
I understand what you mean but my problem is that I can use AXI Stream to interface input video data and output video. And I can't interface map1 and map2 as AXI Stream. The hls::Remap function prototype is :
void Remap(
           Mat<ROW, COL, SRC_T>    &src,
           Mat<ROW, COL, DST_T>    &dst,
           Mat<ROW, COL, MAP1_T>   &map1,
           Mat<ROW, COL, MAP2_T>   &map2);
I can interface src and dst as AXI4 Stream but not map1 and map2 even if they are all hls::Mat object.
Re: hls::Remap
Hi @nyrn3dlab
I think I can try to provide help from checking the source code.. I guess you moved on but this may help other users or someone will have a better answer.
You're interested by hls::Remap() and UG902 describes InitUndistortRectifyMap as : <<Generates map1 and map2, based on a set of parameters, where map1 and map2 are suitable inputs for hls::Remap()>> then reading on <VHLS_INCLUDE_PATH>/hls/hls_video_undistort.h at the very bottom, InitUndistortRectifyMap calls InitUndistortRectifyMapInverse which itself generate those remapping only if MAP1_T==HLS_16SC2;
So I guess this is your answer... use HLS_16SC2 for the type in your code and use InitUndistortRectifyMap  to generate those.
As for all OpenCV designs you would have to use the DATAFLOW directive.
Again this is all based on reverse engineering, not experience and I hope it helps you or others.
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Visitor nyrn3dlab
Re: hls::Remap
Hi @herver!
Thank you very much for yor answer. We moved on and we found another solution. We developed a function in Vivado HLS that considers the camera's parameters to directly output the remapped image with a formula so we left the solution with the hls library using InitUndistortRectifyMap.
Best regards,
Ny
Visitor topshang
Re: hls::Remap
hello,
   can you tell us how to developed a function in Vivado HLS that considers the camera's parameters to directly output the remapped image with a formula?
   what's the formula?
   hope to rely, than you.
