hls co-simulation
Hello, I am using co-simulation with hls. The following warning message will cause the simulation results to not appear.
WARNING: Hls::stream 'hls::stream<ap_axiu<8, 1, 1, 1> >.2' is read while empty, which may result in RTL simulation hanging.
But code synthesis can pass.Below is my top level function, and the test code. Can you help me find out how to solve it?
void ImgPre_L(AXIS8 &vid_inL, AXIS8 &vid_outL, int rows, int cols){
#pragma HLS INTERFACE axis register both port=vid_inL
#pragma HLS INTERFACE axis register both port=vid_outL
#pragma HLS INTERFACE s_axilite port=return
#pragma HLS INTERFACE s_axilite port=rows
#pragma HLS INTERFACE s_axilite port=cols
hls::Window<3, 3, ap_fixed<32,12> > PAR_L_CAMM;
hls::Window<3, 3, ap_fixed<32,2> > PAR_L_RM;
PAR_L_CAMM.val[0][0] = PAR_L_CAMM_RAW[0];
PAR_L_CAMM.val[0][1] = PAR_L_CAMM_RAW[1];
PAR_L_CAMM.val[0][2] = PAR_L_CAMM_RAW[2];
PAR_L_CAMM.val[1][0] = PAR_L_CAMM_RAW[3];
PAR_L_CAMM.val[1][1] = PAR_L_CAMM_RAW[4];
PAR_L_CAMM.val[1][2] = PAR_L_CAMM_RAW[5];
PAR_L_CAMM.val[2][0] = PAR_L_CAMM_RAW[6];
PAR_L_CAMM.val[2][1] = PAR_L_CAMM_RAW[7];
PAR_L_CAMM.val[2][2] = PAR_L_CAMM_RAW[8];
hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_16SC2> hmap1L(rows, cols);
hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_16UC2> hmap2L(rows, cols);
IMG_GRAY imgL_in(rows, cols);
IMG_GRAY imgR_in(rows, cols);
IMG_GRAY imgL_rmap(rows, cols);
IMG_GRAY img_erode(rows, cols);
IMG_GRAY img_dilate(rows, cols);
#pragma HLS DATAFLOW
hls::AXIvideo2Mat(vid_inL, imgL_in);
hls::InitUndistortRectifyMapInverse(PAR_L_CAMM, PAR_L_DISTC, PAR_L_CAMM, hmap1L, hmap2L);
hls::Remap<16>(imgL_in, imgL_rmap, hmap1L, hmap2L, HLS_INTER_LINEAR);
hls::Erode(imgL_rmap, img_erode);
hls::Dilate(img_erode, img_dilate);
hls::Mat2AXIvideo(img_dilate, vid_outL);
return;
#define INPUT_IMAGE_L "left.bmp"
#define OUTPUT_IMAGE "result.bmp"
using namespace std;
using namespace cv;
int main (int argc, char** argv) {
// Load data in OpenCV image format
IplImage* srcl = cvLoadImage(INPUT_IMAGE_L, CV_LOAD_IMAGE_GRAYSCALE);
IplImage* dst = cvCreateImage(cvGetSize(srcl), IPL_DEPTH_8U, 1);
cvShowImage("hls_src", srcl);
AXIS8 srcl_axi;
AXIS8 dst_axi;
// Convert OpenCV format to AXI4 Stream format
IplImage2AXIvideo(srcl, srcl_axi);
ImgPre_L(srcl_axi, dst_axi, 640, 480);
AXIvideo2IplImage(dst_axi, dst);
cvShowImage("hls_dst", dst);
waitKey(0);
return 0;
Thank you
Re: hls co-simulation
Hey @zhang842709698,
You can try to narrow down your issue by running C Simulation with the 'Debug' option checked. Step through the code to see when the warning is issued.
Also, we recommend the xfOpenCV library; the HLS Video OpenCV API's are deprecated.
Nicholas Moellers
Xilinx Worldwide Technical Support
Nicholas Moellers
Hi @zhang842709698
Thanks and Regards,
Aoife
