Yuwei_tt
hls::stream::size() synthesis fail
Dear all, I am trying to implement an decimation FIR filter (Down-sampling filter). In order to ensure the stream buffer function properly, I use `hls::stream::size()` function to check number of elements in the stream buffer. (RATE is the down-sampling rate)
if (x->size() >= RATE){
    READ:for(int i=0;i<RATE;i++)
        x_int = x->read();
However, I got the following error while synthesizing my project:
ERROR: [XFORM 203-733] Function hls::stream::size() (../1061MultiBlockCode/decimate.hpp:22:9) is not synthesizable, it can only be used in C simulation.
ERROR: [HLS 200-70] Pre-synthesis failed.
I am wondering how I can fix this error, or is there any other way of implementation. Thanks!!
Tags (3)
xilinxacct
Instructor
Instructor
@Yuwei_tt The general rule for something being synthesizable is based on something being 'known' (or at least a fixed maximum) at the time of synthesis. Anything that is dynamic in nature is not a good fit.
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed.
xilinxacct
Instructor
Instructor
@Yuwei_tt
If you 'need' a notion of the size that has been put into the stream, (rather than a simple producer/consumer)... you can keep track of the size at production of the things put on the stream... that being said, if you are doing that up front, you may be able to avoid putting the non-needed samples ion the stream in the first place.
Hope that Helps
Yuwei_tt
Thanks a lot!! Keeping track of the stream is an effective solution.
I still wonder why hls::stream::size() is not synthesizable.
xilinxacct
Instructor
Instructor
Hope that Helps
Yuwei_tt
I 've got it! Thank you so much.
