how to merge fully partitioned array ports?
I have the following top level description
void fun(const float In[N], float P[N][3]. ...);
I do a complete partition of the P port in 2nd dimension and make it an interface of bram.
Alas this gives me 3 ports P_0, P_1, P_2 of 32 bits with their own read (AND write despite trim_...)
Is it possible to merge these three ports into a single 96 bit bram port?
Unfortunately during constraint interpretation, the P array is not partitioned yet, so I cannot do array map as the names P_0 etc don't exist yet.
I guess I can make a single 96 bit port and convert it to 3 float later but I don't want to do that at this stage. Any ideas?
Voyager
Voyager
Hey @muzaffer,
I'd change the float P[N][3] to const float P[N][3] and use the following #pragmas to get rid of the read interface as well as separate ports ...
    #pragma HLS INTERFACE ap_memory port=In
    #pragma HLS INTERFACE ap_memory port=P
    #pragma HLS ARRAY_RESHAPE variable=P complete dim=2
Best,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
Hey @muzaffer,
So P is a read/write port or a read only port?
And N I presume is a constant?
Best,
Herbert
@hpoetzl P is a read-only port. All write related ports are pulled to zero in the IP. I am not sure why they are not just trimmed.
Being able to merge them to a single port would be quite nice (ie without declaring a 96 bit vector instead)
Voyager
Voyager
Hey @muzaffer,
Best,
Herbert
