hiku@26
how to parse cosim log file into another
Hi All
I am trying to parse cosim log file which is by default generated by cosim and stored under verilog/report/x.log , is there is a way to force the compiler and simulator to save the user transcript created by printf like pass and fail the design into another log file instead of the default path?
any help I do appreciate
shameera
Hi hiku@26 ,
As this is the infrastructure of the Vivado HLS created project. I mean which folders to be created, where to be created, which files should be created under which folder e.t.c.
So, I don't think there is a way to change the location of the COSIM generated report as there is no switch available to do so.
