hitpmpm@163.com
how to set the port direction for HLS IP
hello everyone
When I designing the my IP using the HLS, I want to have two outputs, one is the data of picture ,the other is the number of pixels named count, but the HLS set the count as in not out automatically , how to solve this problem?  thanks!
int hls_counter_color1(AXI_STREAM_IN& INPUT_STREAM1,
		AXI_STREAM_IN& INPUT_STREAM2, AXI_STREAM_OUT& OUTPUT_STREAM, int thr, int rows,
		int cols,int count)
int temp = 0;
#pragma HLS INTERFACE axis port=INPUT_STREAM1
#pragma HLS INTERFACE axis port=INPUT_STREAM2
#pragma HLS INTERFACE axis port=OUTPUT_STREAM
#pragma HLS RESOURCE core=AXI_SLAVE variable=thr metadata="-bus_bundle CONTROL_BUS"
//#pragma HLS RESOURCE core=AXI_SLAVE variable=count metadata="-bus_bundle CONTROL_BUS"
#pragma HLS RESOURCE core=AXI_SLAVE variable=rows metadata="-bus_bundle CONTROL_BUS"
#pragma HLS RESOURCE core=AXI_SLAVE variable=cols metadata="-bus_bundle CONTROL_BUS"
//#pragma HLS RESOURCE core=AXI_SLAVE variable=flag metadata="-bus_bundle CONTROL_BUS"
//#pragma HLS RESOURCE core=AXI_SLAVE variable=return metadata="-bus_bundle CONTROL_BUS"
#pragma HLS INTERFACE ap_stable port=thr
#pragma HLS INTERFACE ap_stable port=rows
#pragma HLS INTERFACE ap_stable port=cols
u4223374
Advisor
Advisor
Yes, just leave it as "int &". I think if you don't specify any interface type, HLS will do something sensible (ie a direct parallel port, with handshaking enabled).
oliviert
		int cols,int count)
 The variable 'count' cannot be an output it's not a pointer nor a reference.
Turn it into:
int& count
And it should be OK.
Olivier Trémois
XILINX SW Marketing AI Engine Tools
Don't forget to reply, give kudos, and accept as solution.
u4223374
Advisor
Advisor
To add to the excellent reply above - you will need to read up on "pass by value" (what you're doing now), "pass by address", and "pass by reference" (what was suggested above). These are crucial concepts in C, and if you do not understand them then you are going to spend a huge amount of time troubleshooting incredibly simple problems.
hitpmpm@163.com
@oliviert @u4223374 Thanks for your reply, I have changed the count into an arrary  like the following
		int cols,int count[1])
 but I get into the trouble that which synethsis port can I set for count , fifo ?axis?or bram?  or others?  The count port is just a number of gray pixels, It decides the IP( behind this IP )whether works.
thanks!
u4223374
Advisor
Advisor
hitpmpm@163.com  I've always used AXI Lite for talking to a Zynq PS. For direct fabric use, I'd use the suggestion from @oliviert and define it as "int & count", since that prevents HLS trying to use it as an array.
hitpmpm@163.com
thanks sir
I want to let the count talk to PL, which port should I use? Do you stilll suggest use int&?
BEST WISHES!
u4223374
Advisor
Advisor
hitpmpm@163.com
I make it!Thank you very very much!
hitpmpm@163.com
I found that the port is disigned as ap_vld port by HLS automatically, but I do not know how to make the ap_vld work?  or can you tell me which port maybe more easy to operate?
thanks!
u4223374
Advisor
Advisor
ap_vld should produce two ports: data and vld. When vld is 1, that means that the data port contains valid data and can be read safely. When vld is 0, that means that the block is processing and the data value may be invalid.
