kuangjiqingma
how to use a picture to equalize itself?
I design to use a framebuffer to store the picture after the picture coming in the IP.Simluation is successful but the IP core does not work in the hardware.
u4223374
Advisor
Advisor
The problem is that for the approach you're using, you need to buffer the whole image on-chip. The image is 1920x1080, so you need to make the stream that's storing it (img_7) at least 2,073,600 elements long. You can do this with the STREAM pragma:
#pragma HLS STREAM variable=img_7.data_stream depth=2097152
(note: it's often wise to make the stream a bit bigger than it technically has to be)
However, once you do this you'll find another problem: an 8-bit stream that long requires 1024 BRAM_18K blocks. This will not fit in any chip smaller than a Zynq 7100 or Kintex 355T (or any of the Virtex 7 line).
kuangjiqingma
I try in this way .HLS report the utilization of BRAM is 92%,but when I implement hardware in Vivado ,error is happened.The report is the utilization of LUTRAM and LUT is exceed.As the follow picture.
