drjack
how to use functions from HLS math libraries in SDSoC
I am having trouble using functions from HLS Math library in my hardware accellerated functions in SDSoC in 2018.2 (on Windows 10).
I am including the header file for the HLS Math library as:
#include <hls_math.h>
And, I am trying to call the functions in my hardware accelerated function as:
float umag = hls::sqrt(umagsq);
float c  = cos(theta);
However, the getting the following error during build:
undefined reference to `hls::sqrt(float)'
undefined reference to `hls::cos(float)'
I am probably missing something.  Any help will be appreciated.
Thanks...
wenchen
Hi @drjack
Can you find the hls::math library in your project include dictionary?
From the user guide, hls::sqrt(float) and hls::cos(float) are supported in the hls math library.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug902-vivado-high-level-synthesis.pdf
Wen
**~ Got a minute? Answer our Vitis HLS survey here! ~**
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
