jiajiahao069
init mat type
I have cpp source code that need to tranlslate to hls.
One sentence is the following.
Mat img_128(img_rows, img_cols, CV_32F, 128);
Do you have any idea how to init this Mat type? Put the xf::mat in the stream port?
scampbell
Hello @jiajiahao069 ,
I think the best information to be found for the MAT class is located here:
https://xilinx.github.io/Vitis_Libraries/vision/2020.1/api-reference.html#xf-cv-mat-image-container-class
There are different class constructors to use and those are described there, with the one most likely to be of interest to you is:
  Mat(int _rows, int _cols, void* _data);
This would be initialized similar to that of the OpenCV matrix class where you declare a data array containing the initial values such as:
float data[10] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 };
cv::Mat opencv_matrix = cv::Mat(1, 10, CV_32F, data);
In HLS, arrays containing initial values will be initialized by incrementing through all of the array indices and writing the value, which for a large array, can be a significant source of latency, so caution is required to ensure this is absolutely necessary such as fixed values - a ROM.
OK, I hope this helps,
Scott
jiajiahao069
Hi @scampbell
Thanks for replying.
I did some tests about intinal the mat. But have some issues.
I want to initial the xf::cv::Mat<XF_8UC1,1080,1920,NPC> img_128 array. And I want to make the img_128_hls like a stream through in a processing ip.
I did it like the following code.
xf::cv::Mat<XF_8UC1,1080,1920,NPC> img_128_hls
for (int i = 0; i < 1080; i++)//上下
for (int j = 0; j < 1920; j++)
img_128_hls.data[i*img_cols+j] = 100;
and I initial a mat array in C-modle.
cv::Mat img_128;
img_128.create(cv::Size(1920,1080),CV_8UC1);
for (int i = 0; i < img_rows; i++)//上下左右
for (int j = 0; j < img_cols; j++)
//img_128.at<uchar>(i, j) = 5;
img_128.at<uchar>(i,j) = 100;
But I use
xf::cv::absDiff(img_128,img_128_hls, diff);
xf::cv::analyzeDiff(diff, 5, err_per);
get the final results
Minimum error in intensity = 100.000000
Maximum error in intensity = 100.000000
Percentage of pixels above error threshold = 100.000000
Could you tell me the reason why all pixels are wrong?
jrjong11
Scott
Thnks mate. will try roadrunner email this one
