invalid arguments'candidates are:double svm_predict(const svm_model*,const svm_node*)
error: expected unqualified-id
Res = svm_predict_values(LabelS1,SStest1, model);
Res = svm_predict(LabelS1,SStest1, model);
refer this readme file if you are using function correctly .
https://github.com/cjlin1/libsvm/blob/master/README
check design here and and see if you can run it correctly
Thanks and Regards
Balkrishan
