daniel.cogan
largest fixed point return value
What is the largest ap_fixed<> that the compiler will correctly return through a function call?
My ap_fixed<52,39> value was changed to a smaller number upon return.  I had to shift and cast to a long long int, and unshift back after the return in order to get the correct value.
Similarly a coworker tried returning a 3D array [2][2][2]  of ap_fixed<40,1>, and was getting values that didn't match the array right before the return from function call.
Just curious what the rules are involving ap_fixed as a return type.
aoifem
Hi @daniel.cogan
I don't know an exact number, as I image it would change depending on your system. But if you are looking to increase the precision I would look at playing around with the quantization mode. There's more information about this in the docs:
https://www.xilinx.com/html_docs/xilinx2020_1/vitis_doc/vitishlslibrariesreference.html
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
xilinxacct
Professor
Professor
@daniel.cogan
Arbitrary precision data types are provided for C and C++ and allow you to model data types of any width from 1 to 1024-bit. according to UG902
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed.
daniel.cogan
That does.
In terms of this question, I'm concerned with preserving integer bits within the arbitrary precision data type, as a return value in a function.  In my case, the ap_fixed<> is defined with 59 integer bits. Printing before the end of the function showed the expected large value.  Printing the return value right after the return from the function, showed a different smaller value.
Do you expect that function calls within HLS can handle the full range of arbitrary precision data types (of 1 to 1024 bits) as return values?  Does it matter if they are returned as a pointer or returned as the function return value? I have some unexplained instances in which the value did not return properly.
However, of course when I went to make a small test project to show this behavior, I haven't been able to yet.
