latency of sub-function and top level function
we are trying a synthesis of top level function update_order () which gives latency and Initiation interval of (27-min,45-max) and (19-min,45-max) respectively. If we examine the analysis view, however, the functions in the hierarchy are giving latency and II of (18, 44), (18,44) and (15,15), (15,15) respectively. Also these functions in hierarchy seem to be executing sequentially from analysis view. So the top level function should give a latency of (42 - min, 60-max) respectively. Can someone explain this  please. we are attaching the necessary diagrams herewith.
Voyager
Voyager
Re: latency of sub-function and top level function
Hey mahesh.barve@tcs.com,
I don't know your functions (as you didn't provide them), and the values you give do not add up for me either ...
  • 18 + 15 = 33
  • 44 + 15 = 59
... but the fact that you expect (42/60) and get (27/45) just means that 15 cycles could be optimized (probably by pipelining) away when the two functions exchange data.
  • 42 - 15 = 27
  • 60 - 15 = 45
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
