lalitbhambhani
libtbb.so.2: undefined reference
I'm getting the following error when I run CSim using Vitis HLS 2020.2. I have this file in the location shown by the error message and assuming its not the correct version. I don't see a version supplied by Vitis HLS 2020.2 and couldn't find a solution for this.
/usr/lib/x86_64-linux-gnu/libtbb.so.2: undefined reference to `__cxa_init_primary_exception@CXXABI_1.3.11'
/usr/lib/x86_64-linux-gnu/libtbb.so.2: undefined reference to `std::__exception_ptr::exception_ptr::exception_ptr(void*)@CXXABI_1.3.11'
collect2: error: ld returned 1 exit status
make: *** [csim.exe] Error 1
ERROR: [SIM 211-100] 'csim_design' failed: compilation error(s).
Any suggestions would be appreciated. Thanks!
Tags (3)
lalitbhambhani
@nikotesla
I launched my old VM and uninstalled OpenCV and then tried your solution.
I already had TBB turned off but I had CUDA ON so decided to turn that OFF and installed OpenCV. After that I was able to get CSim and CoSim to compile and show simulations properly.
Thanks!
nikotesla
I'm getting the same problem when running Csim on vitis HLS 2020.2
Did you resolve the problem yet?
NT
lalitbhambhani
I'm running 2020.2 on Linux OS in virtual machine. I decided to create a new VM and did a fresh install of the OS and 2020.2 then got it to work.
I'm still looking for answer for this problem.
nikotesla
I have also resolved the problem.
In my case, just need to turn off TBB when configuring CMAKE. My previous configuration was
cmake -D CMAKE_BUILD_TYPE=RELEASE \
            -D CMAKE_INSTALL_PREFIX=$cwd/installation/OpenCV-"$cvVersion" \
            -D INSTALL_C_EXAMPLES=ON \
            -D INSTALL_PYTHON_EXAMPLES=ON \
            -D WITH_TBB=ON \
            -D WITH_V4L=ON \
            -D OPENCV_PYTHON3_INSTALL_PATH=$cwd/OpenCV-$cvVersion-py3/lib/python3.5/site-packages \
        -D WITH_QT=ON \
        -D WITH_OPENGL=ON \
        -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib/modules \
        -D BUILD_EXAMPLES=ON ..
My current configuration is:
		-D CMAKE_INSTALL_PREFIX=/home/tesla/Tools/opencv/OpenCV-3.4.4 \
		-D WITH_CUDA=OFF \
		-D OPENCV_ENABLE_NONFREE=ON \
Then reinstall OpenCV.
PS: I followed the guide here (https://learnopencv.com/install-opencv-3-4-4-on-ubuntu-18-04/) to install OpenCV.
Hope that can help.
TN
lalitbhambhani
@nikotesla
Thanks!
