Visitor tobu
loop unrolling not as expected
I'm performing a simple example of a multiplication of an array by a constant value. I defined the load and store function that bring inside my top func the data to two local variables (the interface with the multiplication) and i defined them the cyclic partitioning pragma (so multiplier have data ready at every clock cycle ).
I synthesized and work well till the 8th factor of unrolling; From the 8 on, Vivado inserts some sort of logic that i do not understand (it is not inserting just the multiplier in parallel as i was expecting but the urem function etc). When i unroll by 16 everything works well. (as i change the unrolling faction I also change the partitioning factor in order to match) .
The code is:
void top(fx_pt* out, fx_pt* wave,fx_pt c, int nSample)
#pragma HLS INTERFACE s_axilite register depth=1 port=nSample bundle=CTRL_BUS
#pragma HLS INTERFACE s_axilite register depth=1 port=c bundle=CTRL_BUS
#pragma HLS INTERFACE m_axi depth=1200 port=wave offset=slave bundle=SRC_BUS
#pragma HLS INTERFACE m_axi depth=1200 port=out offset=slave bundle=DST_BUS
#pragma HLS INTERFACE s_axilite port=return bundle=CTRL_BUS
    fx_pt _inbuff[SIZE];
#pragma HLS ARRAY_PARTITION variable=_inbuff cyclic factor=10 dim=1
	fx_pt _outbuff[SIZE];
#pragma HLS ARRAY_PARTITION variable=_outbuff cyclic factor=10 dim=1
   load(_inbuff, wave,  nSample);
   multiply_constant(_outbuff,_inbuff,c,nSample);
   store( _outbuff, out,  nSample);
where fp_pt are ap_fixed<16,10> .
void load(fx_pt _inbuff[SIZE],fx_pt wave[SIZE], unsigned nSample){
#pragma HLS INLINE off
load:
	for(unsigned i=0;i<nSample;i++)
#pragma HLS LOOP_TRIPCOUNT min=1200 max=1200 avg=1200
		_inbuff[i]=wave[i];
Same the store.
void multiply_constant(fx_pt out[SIZE], fx_pt data[SIZE], fx_pt c,unsigned nSample)
mult_c_samples:
    for(unsigned j=0;j<nSample;j++)
#pragma HLS UNROLL skip_exit_check factor=10
    	out[j] = c* data[j];
This is the strange circuit synthesized:
While when i unroll for a factor <8 or 16, i obtain this, as expected:
Can you give me some advice of why Vivado is not working as I'm expecting? where I'm wrong?
Thank you so much for your help.
