Observer yetanotherid
memcpy causing PL module to hang
I'm working with a Zynq, and have an HLS module using memcpy over an axi master to access DDR memory. Since the axi transactions use handshaking, I would expect that no matter what, eventually the HLS module will be able to complete its reads and writes, even if the DDR memory controller is off servicing some other request.
However, I'm observing my module completely hang in some circumstances. It appears the axi bus is in an "overflow" state which I haven't been able to find any documentation on. Can anyone shed some light on this state? Below is a hardware capture of such an event.
Re: memcpy causing PL module to hang
@yetanotherid
This seems to be caused by an ILA parameter which is not automatically propagated from the AXI bus.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
