hafiz
qsort() alternative
Hi, i am using qsort() function in my code and it cannot be synthesize. What is the alternative that can be use? or what else should i do?
u4223374
Advisor
Advisor
I don't think HLS has support for any sorting algorithm by default, but writing a mergesort is not difficult - and it is very FPGA-friendly.
u4223374
Advisor
Advisor
hafiz
thank you for the suggestion, I will give it a try.
Edit: I made it, thank you so much!
