jwizard93
"Include directories" disappear?
Hello all,
I'm new to HLS and just playing around I came across something strange that I don't understand.
In a new project with one source file I cannot synthesize because a required header file is not found.
I right-click on my source file. Under C/c++ General -> Paths and Symbols I add the proper include directory. Then I hit apply.
I now see my directory in the project explorer under includes and expanding it I can verify that the header file I need is in that directory.
I try synthesis again. I get the same exact result. Furthermore, my include directory vanishes from the project explorer and from within the properties window of my source file.
What is going on here?
brucey
I file one CR to be investigated.
For now, you can just put head file and source file in the same directory.
brucey
