recursive function not supported in vivado hls synthesis
Hello
I am woring on Fast Fourier Transform algorithm and my C code has recursive function.
When I am trying to do synthesize its showing error of not supported recursive functions. Can I change it to while loop and stack. If I change my code then is synthesize works?
Madhuri
Re: recursive function not supported in vivado hls synthesis
Why are you cross-posting?
I like these books:
Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books
VHDL for Logic Synthesis, Andrew Rushton
FPGA Prototyping by VHDL Examples, Pong P Chu
A while loop is supported for synthesis. Also, refer to the User Guide. If you search for recursion you'll find an example of recursion using templates: the secret is to have a termination template so that it's not infinite.
Duncan
