synthesis pass but post synthesis simulation fail
I am following trd03 to generate bitstream under Ubuntu. After generating the bitstream file, it showed synthesis failed. The message is as follows:
  • [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xcku040'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
I have double checked the license, it's totally OK. And when I change to Win10, there is no problem with it. I believe Ubuntu and win10 are sharing the same host IP of the computer.
Re: synthesis pass but post synthesis simulation fail
You are right, but the solution of the link has some little details to add.
The solution for Ubuntu 18.04.1 LTS:
Get the Ethernet Adapter renamed to eth0 (Ubuntu 18.04.1 LTS):
1: cd /etc/default
sudo vi grub
2: press "i" to get into insert mode of vi editor
change [GRUB_CMDLINE_LINUX=""] to [GRUB_CMDLINE_LINUX="net.ifnames=0 biosdevname=0"] (add 'net.ifnames=0 biosdevname=0')
Esc, ':', 'x' to save and exit
3: sudo grub-mkconfig -o /boot/grub/grub.cfg (to generate a new grub file)
4: reboot
Of course you need to open the terminal with Ctrl+Alt+T first.
Hope that will help all the people facing the same problem.
The total Tcl Console is attached.
Hi @yzzhsx12345,
At first from the title and the description of the post, the issue is not clear. I think that you are facing issues in Vivado. Tool will not give errors regarding synthesis after generating bitstream as synthesis takes places at the earlier flow itself.
As I understand that for the same machine if you are using windows 10 then you are facing no issues and when changed to Linux you are facing issues with license then it might be the scenario of Ubuntu machine unable to detect the Host ID of the machine. Please follow the AR#60510 and see if it helps.
1: cd /etc/default
sudo vi grub
4: reboot
