04-20-2017 09:21 AM
Hi guys,
when executing a tcl script it would be useful know what vivado_hls version is running.
Unfortunately the tcl command I use in Vivado Design Tool:
[version -short]
doesn't work with vivado_hls.
Someone did find a workaround?
10-30-2017 04:57 AM
I did forget about this post for some time. Meanwhile I have developed my own solution. Here the TCL procedure I use in my current scripts
# # TCL procedure that identifies the Vivado_hls version simply looking # inside the path environment variable. Usage example: # "set Vivado_ver [VivadoVer]" # Tested on Vivado versions: 2017.3, 2017.2, 2016.4, 2016.3, 2016.1, 2015.4, 2014.4 # proc VivadoVer {} { set position_VivadoHlsVer [lsearch [file split $::env(PATH)] Vivado_HLS]+1 set position_VivadoVer [lsearch [file split $::env(PATH)] Vivado]+1 set position_SdkVer [lsearch [file split $::env(PATH)] SDK]+1 if {${position_VivadoHlsVer}>0} { set Vivado_ver [lrange [file split $::env(PATH)] ${position_VivadoHlsVer} ${position_VivadoHlsVer}] puts "\[VivadoVer{}\] Found 'Vivado_HLS' string in the path, ver: $Vivado_ver" } elseif {${position_VivadoVer}>0} { set Vivado_ver [lrange [file split $::env(PATH)] ${position_VivadoVer} ${position_VivadoVer}] puts "\[VivadoVer{}\] Did not find 'Vivado_HLS' string in the path but have found 'Vivado', ver: $Vivado_ver" } elseif {${position_SdkVer}>0} { set Vivado_ver [lrange [file split $::env(PATH)] ${position_SdkVer} ${position_SdkVer}] puts "\[VivadoVer{}\] Did not find 'Vivado_HLS' string in the path but have found 'SDK', ver: $Vivado_ver" } else { set Vivado_ver "UNKNOW" puts "\[VivadoVer{}\] Did not find any 'Vivado' string in the path, ver: $Vivado_ver" } return $Vivado_ver }
Depending on the Vivado version I run, I had got different "$path" variables with or without the "Vivado_HLS" string inside. Here some usage example:
2017.2
$ source /soft/Xilinx/Vivado/2017.2/settings64.csh $ tclsh % set Vivado_ver [VivadoVer] [VivadoVer{}] Found 'Vivado_HLS' string in the path, ver: 2017.2 2017.2
2017.3
$ source /soft/Xilinx/Vivado/2017.3/settings64.csh
$ tclsh
%set Vivado_ver [VivadoVer] [VivadoVer{}] Did not find 'Vivado_HLS' string in the path but have found 'Vivado', ver: 2017.3 2017.3
2014.4
$ source /soft/Xilinx/Vivado/2014.4/settings64.csh
$ tclsh
% set Vivado_ver [VivadoVer] [VivadoVer{}] Found 'Vivado_HLS' string in the path, ver: 2014.4 2014.4
Does anyone have a better solution ?
10-27-2017 10:31 AM
I had the same error but I just realized I had to run vivado, not vivado_hls.
10-30-2017 04:57 AM
2017.2
2017.3
$ tclsh
2014.4
$ tclsh
