variable bit widths on sc_fifo
using an example (sc_FIFO_port) I changed sc_fifo to use sc_lv<72> (to control a datamover)  It doesn't seem to compile.
how do I specify a systemc fifo 72 bits wide?  I've tried many other combinations, not just sc_lv.  None seem to work.
SC_MODULE(sc_FIFO_port)
//Ports
sc_in <bool> clock;
sc_in <bool> reset;
sc_in <bool> start;
sc_out<bool> done;
sc_fifo_out<sc_lv<72>> dout;
sc_fifo_in<sc_lv<72>> din;
//Variables
int share_mem[100];
bool write_done;
//Process Declaration
void Prc1();
void Prc2();
//Constructor
SC_CTOR(sc_FIFO_port)
//Process Registration
SC_CTHREAD(Prc1,clock.pos());
reset_signal_is(reset,true);
SC_CTHREAD(Prc2,clock.pos());
C:/Xilinx/Vivado/2018.2/common/technology/autopilot/ap_int_syn.h:6542:3044: note: candidate template ignored: failed template argument deduction
template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::plus operator + ( const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator + (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::plus operator + ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator + (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::minus operator - ( const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator - (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::minus operator - ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator - (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::mult operator * ( const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator * (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::mult operator * ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,
_AP_Q,_AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator * (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::div operator / ( const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator / (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::div operator / ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator / (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::arg1 operator >> ( const ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator >> (ap_int_base<64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::arg1 operator << ( const ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator << (ap_int_base<64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::logic operator & ( const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator & (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,
false>::logic operator & ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator & (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::logic operator | ( const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator | (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::logic operator | ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator | (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::logic operator ^ ( const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator ^ (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) typename ap_fixed_base<_AP_W,_AP_I,_AP_S>::template RType<64,64,false>::logic operator ^ ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator ^ (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator == ( const ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator == (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator == ( ap_ulong i_op, const ap_f
ixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator == (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator != ( const ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator != (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator != ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator != (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator > ( const ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator > (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator > ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator > (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator >= ( const ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator >= (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator >= ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator >= (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator < ( const ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i
_op) { return op.operator < (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator < ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator < (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator <= ( const ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator <= (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) bool operator <= ( ap_ulong i_op, const ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op) { return ap_fixed_base<64,64,false>(i_op).operator <= (op); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& operator += ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator += (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& operator -= ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator -= (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& operator *= ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator *= (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed
_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& operator /= ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator /= (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& operator >>= ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator >>= (ap_int_base<64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& operator <<= ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q,_AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator <<= (ap_int_base<64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& operator &= ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator &= (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& operator |= ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator |= (ap_fixed_base<64,64,false>(i_op)); } template<int _AP_W, int _AP_I, bool _AP_S, ap_q_mode _AP_Q, ap_o_mode _AP_O, int _AP_N> inline __attribute__((always_inline)) ap_fixed_base<_AP_W,_AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& operator ^= ( ap_fixed_base<_AP_W, _AP_I,_AP_S,_AP_Q, _AP_O, _AP_N>& op, ap_ulong i_op) { return op.operator ^= (ap_fixed_base<64,64,false>(i_op)); }
In file included from sc_FIFO_port.cpp:1:
In file included from sc_FIFO_port.cpp:92:
./sc_FIFO_port.h:107:29: error: type name requires a specifier or qualifier
./sc_FIFO_port.h:107:29: warning: declaration does not declare anything [-Wmissing-declarations]
./sc_FIFO_port.h:108:24: error: use of undeclared identifier 'din'
./sc_FIFO_port.h:108:27: error: type name requires a specifier or qualifier
./sc_FIFO_port.h:108:27: warning: declaration does not declare anything [-Wmissing-declarations]
Re: variable bit widths on sc_fifo
fixed it.  Looks like it was a missing space in the template
to
sc_fifo_out<sc_lv<72> > dout;
sc_fifo_in<sc_lv<72> > din;
to
