nagarishitha12
vivado HLS script
hi,
can anybody help me how to run the scripts generated by vivado HLS tool after co simulation?
brucey
After you generated C/RTL Co-simulation scripts, open one HLS Command Prompt. Change directory to project_path/solution_name/sim/Language. Call sim.bat.
This is for Windows.
For Linux, I think the steps should be similar, but some commands/scripts may be a bit different.
brucey
