vivado hls exported ip not visibe in ip catalog
I am creating an ip using vivado_hls this is an example project I exported RTL and this is added to my vivado suite IP catalog. But it is invisible to be added in block diagram. As can be seen in first snap IP is successfully added in the second snap its invisible. Please help me figure out what might go wrong. I have tried this in vivado 2015.4 and 2016.4
Hemanth
Re: vivado hls exported ip not visibe in ip catalog
@hemanthsingh_in
While creating the Vivado project, make sure that you use the same device as used in the HLS project.
Nupur
Please find the attached project
Hemanth
@balkris: I have attached project in my previous post
@hemanthsingh_in
Nupur
HI @nupurs,
I did try this it doesn't work
@nupur Thank you. I need to create a new project with same device. I was just changing the part number of existing project and this doesn't work, but new project does
