where can i find C test bench from the file generated from matlab'codegen'
Accepted Solution Solved
Accepted Solution
ERROR: [SIM 211-104] Cannot find C test bench. Please specify test bench files using 'add_files -tb'.
i generate my matlab code to c code with "the matlab coder"to implement in FPGA , i get is this error "ERROR: [SIM 211-104] Cannot find C test bench. Please specify test bench files using 'add_files -tb'." and  i have many c files i can not distinguished which is the test bench . Can you tell me what i do for this error ?
Re: where can i find C test bench from the file generated from matlab'codegen'
matlab coder mathworks product please contact mathwork for the matlab coder file generation
Thanks and Regards
Balkrishan
All Replies
Thanks and Regards
Balkrishan
As @balkris has said, this is mainly a problem for Mathworks. It's definitely not an issue with any Xilinx product.
With that said, I'd really question why you're using Matlab to generate a C testbench. Normally you'd use Matlab to generate test data and corresponding "gold" data (ie what the answers should be), then write a simple C testbench that feeds the test data to the HLS module and checks the results.
