Observer a1300012709
why this add operation consumed 4 dsp?
and this is the code:
for(int col = 0; col < Q; col+=4)
data_tf add_rst[4][4] = {0};
// out_buf[0][col][to] = 0,out_buf[0][col+1][to] = 0,out_buf[0][col+2][to] = 0,out_buf[0][col+3][to] = 0;
// out_buf[1][col][to] = 0,out_buf[1][col+1][to] = 0,out_buf[1][col+2][to] = 0,out_buf[1][col+3][to] = 0;
// out_buf[2][col][to] = 0,out_buf[2][col+1][to] = 0,out_buf[2][col+2][to] = 0,out_buf[2][col+3][to] = 0;
// out_buf[3][col][to] = 0,out_buf[3][col+1][to] = 0,out_buf[3][col+2][to] = 0,out_buf[3][col+3][to] = 0;
C_loop: for(int tn = 0; tn < C; tn+=tile_c)
#pragma HLS PIPELINE
tile_c_loop: for(int tnn = 0; tnn < tile_c; ++tnn)
data_tf array[4][4];
data_tf in_buf[6][6];
int tnnn = tn + tnn;
for(int i = 0; i < 6; ++i)
in_buf[0][i] = buf_line_1[col+i][tnnn];
in_buf[1][i] = buf_line_2[col+i][tnnn];
in_buf[2][i] = buf_line_3[col+i][tnnn];
in_buf[3][i] = buf_line_4[col+i][tnnn];
in_buf[4][i] = buf_line_5[col+i][tnnn];
in_buf[5][i] = buf_line_6[col+i][tnnn];
from analysis, it shows that 'col+i' consume 4 dsp.
I am confused, because it's just an add operation, why the final module indicated it was a 'mul'.
Scholar u4223374
Re: why this add operation consumed 4 dsp?
It's using the DSPs for array indexing.
There's no such thing as a "2D array", in either C or HDL. In both cases it's just a 1D array which the compiler or synthesis tool has accessed in a way that makes it look 2D.
Say you're at this line:
"buf_line_5" is a (Q+2)*C array and "in_buf" is a 6*6 array. For now, let's say that the variables are:
i = 5;
col = 4;
tnnn = 7;
in_buf[4][i] is therefore in_buf[4][5]. Its position in the "real" 1D array is 4*6 + 5 = 29. Finding this address requires computation of 4*6, which costs one DSP slice (unless HLS is smart and recognises that it's always multiplying by 4 here).
buf_line_5[col + i][tnnn] is buf_line_5[9][7]. Its position in the "real" 1D array is C*9 + 7. Again, this costs at least one DSP slice - perhaps quite a few more if C is a large number.
In addition to this, you've unrolled the loop (by putting it under a PIPELINE directive), so HLS is potentially having to do this multiplication for every element in the array simultaneously, requiring even more DSP slices.
In terms of fixes: if you can make the dimensions powers of 2, that eliminates DSP slices. For example, in_buf only needs to be 6*6 (36 elements), but if you make it 8*8 instead (or even 6*8) then the multiplication for addressing is always just "*8" - which is the same as a 3-bit shift.
Edit: as for why the "add" operation is apparently consuming DSPs: the DSP48 slice can perform operations of the form "(A+D)*C+B", which is exactly what you need (A = col, D = i; C = C; B = tnnn). HLS is probably using a single slice to do the entire calculation. Since the first thing that uses that slice is the (A+D) addition, the resource usage is being "assigned" to that operation, even though the slice is actually doing quite a lot more.
In the HLS tool Xilinx provided HLS coding example template . You can use these example and see if you can better performance.
Thanks and Regards
Balkrishan
Scholar u4223374
i = 5;
col = 4;
tnnn = 7;
Thank you very much for your reply.
Actually, a constant multiply(like 7*i) won't consume DSP in HLS.
for example:
data_tf transform1_input[6][6];
data_tf transform_output[4][6];
when synthesizing this loop, no DSP was used(even replace *2,*4 with *5,*7, the compiler is clever enough).
In addition,
Even if I have calculated the index number before the loop, it also consumed extra DSP.
I am really confused
checks these links it may help you
http://www.wiki.xilinx.com/HLS+Filter2D
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/hls-mat-to-2d-array/td-p/651195
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/2015-4-2D-convolution-with-linebuffer-example-RTL-cosim-fails/td-p/690016
https://youtu.be/38lj0VQci7E
https://www.youtube.com/watch?v=4nG68rZaFGs
Thanks and Regards
Balkrishan
Scholar u4223374
Huh, that's news to me. It's always insisted on using DSP slices for constant multiplication for me, unless the multiplication is a constant power of two (converted to a shift) or both inputs are constants (multiplied at compile-time). You can definitely force it to use a LUT multiplier instead of a DSP slice, and that may well make sense for constant values (after all, multiplying by five is just a free bit-shift and a single addition) but I've never seen HLS do it automatically.
In your new example, I suspect that it's still having trouble with the unrolled loop. At some point, it has to calculate ((col + <constant>) * C) + tnnn). I don't know of any way to stop it doing that for each constant value individually, apart from switching to a 1D array and doing some minor buffering:
int buf_line_1[(Q+2)*C];
int buf_line_2[(Q+2)*C];
int buf_line_3[(Q+2)*C];
int buf_line_4[(Q+2)*C];
int buf_line_5[(Q+2)*C];
int buf_line_6[(Q+2)*C];
int Q_tmp = 0;
for (int col = 0; col < Q; col+= 4) {
	index_tmp[0] = Q_tmp + tnnn;
	index_tmp[1] = Q_tmp + C + tnnn;
	index_tmp[2] = Q_tmp + 2*C + tnnn;
	index_tmp[3] = Q_tmp + 3*C + tnnn;
	index_tmp[4] = Q_tmp + 4*C + tnnn;
	index_tmp[5] = Q_tmp + 5*C + tnnn;
	Q_tmp += 4*C;
	for (int tn = 0; tn < C; tn += tile_c) {
		for (int tnn = 0; tnn < tile_c; tnn++) {
			for (int i = 0; i < 6; i++) {
				for (int j = 0; j < 6; j++) {
				in_buf[j][i] = buf_line_1[index_tmp[j]];
As far as I can tell, this guarantees that the only multiplication is constant * constant.
I think this problem may result from the directives of array_partition. if the loop is not pipelined, and the array is a block, no dsp was used to calculate the index (like a[col+i][j]=b[i][j]).
