adel_chaker
writing and reading in the same array
I'm a student working on a project, and I encountered the following problem:
my goal is to store a certain number of coef in an array, to use them in a calculation function. After a few tries I realized that the maximum number of calculation functions I can parallel is 8. So I fix my code with #pragma to limit the number of parallel function calls.
But the problem I have now is that even though I have limited the number of calls to the parallel calculator function, it reads and stores all the coefficients, whereas I just want to store the coefficients needed for the 8 current calculator functions.
void top_level_function(char coef_array[TOTAL_NUMBER_OF_ARRAY])
//Code
main_loop:...
#pragma HLS PIPELINE
interne_loop: for all coefs
partiel_loading_of_array_loop:{#pragma HLS array_partition variable=partiel_coefs complete}
#pragma HLS allocation instances=calcul limit=8 function
calcul()
I also tried to create a function to partially load the coefficients and do a pragma like for the calculate function but it doesn't work. It creates dependencies between the select operation and the zext operation.
in other words I would like that when I load the necessary coefs for the calculation part, I would like to reuse this same space to store the next coefs.
thank you in advance for your precious help.
u4223374
Advisor
Advisor
Could we possibly get the complete code? It's sort of hard to see what's going on with such a small example.
There are basically two ways to achieve what you're requesting. One is to have a loop containing two functions, one preparing the buffer and the other using it:
for (int i = 0; i < 1000; i++) {
	prepare_buffer(buff_A);
	use_buffer(buff_B);
	// Swap buffers
	buff_C = buff_A;
	buff_A = buff_B;
	buff_B = buff_C;
Except that HLS doesn't appreciate this method of swapping buffers, and you need a bunch more control code to handle start/end cases. Nevertheless, this is the way I always end up using.
The other approach is to use dataflow:
#pragma HLS DATAFLOW
#pragma HLS STREAM variable=buff depth=10
prepare_buffer(buff);
use_buffer(buff);
This tells HLS to just stream the data from prepare_buffer to use_buffer, with only a small number of elements held at any time. Streaming puts a number of limitations on accessing the elements (eg. must be in order, must read/write every element exactly once) but it should give both better performance and fewer resources. However, the latest version of HLS that I regularly use is 2016.2, and in that the whole dataflow system is pretty fragile. Hopefully it's better in newer versions.
u4223374
Advisor
Advisor
	use_buffer(buff_B);
	// Swap buffers
	buff_C = buff_A;
	buff_A = buff_B;
	buff_B = buff_C;
use_buffer(buff);
adel_chaker
Thank you very much.
after reading some of the dataflow examples and the questions on the forum. i was able to answer a lot of questions.
I was able to move forward, after a synthesis of my project. I get for the port of coefs:
// KERNEL_BUS
// 0x0100 ~
// 0x01ff : Memory 'kernel_0' (256 * 8b)
//          Word n : bit [ 7: 0] - kernel_0[4n]
//                   bit [15: 8] - kernel_0[4n+1]
//                   bit [23:16] - kernel_0[4n+2]
//                   bit [31:24] - kernel_0[4n+3]
// 0x0200 ~
// 0x02ff : Memory 'kernel_1' (256 * 8b)
//          Word n : bit [ 7: 0] - kernel_1[4n]
//                   bit [15: 8] - kernel_1[4n+1]
//                   bit [23:16] - kernel_1[4n+2]
//                   bit [31:24] - kernel_1[4n+3]
// 0x0300 ~
// 0x03ff : Memory 'kernel_2' (256 * 8b)
//          Word n : bit [ 7: 0] - kernel_2[4n]
//                   bit [15: 8] - kernel_2[4n+1]
//                   bit [23:16] - kernel_2[4n+2]
//                   bit [31:24] - kernel_2[4n+3]
// 0x0400 ~
#define XCONV_3D_PARALLEL_KERNEL_BUS_ADDR_KERNEL_0_BASE   0x0100
#define XCONV_3D_PARALLEL_KERNEL_BUS_ADDR_KERNEL_0_HIGH   0x01ff
#define XCONV_3D_PARALLEL_KERNEL_BUS_WIDTH_KERNEL_0       8
#define XCONV_3D_PARALLEL_KERNEL_BUS_DEPTH_KERNEL_0       256
#define XCONV_3D_PARALLEL_KERNEL_BUS_ADDR_KERNEL_1_BASE   0x0200
#define XCONV_3D_PARALLEL_KERNEL_BUS_ADDR_KERNEL_1_HIGH   0x02ff
#define XCONV_3D_PARALLEL_KERNEL_BUS_WIDTH_KERNEL_1       8
#define XCONV_3D_PARALLEL_KERNEL_BUS_DEPTH_KERNEL_1       256
#define XCONV_3D_PARALLEL_KERNEL_BUS_ADDR_KERNEL_2_BASE   0x0300
#define XCONV_3D_PARALLEL_KERNEL_BUS_ADDR_KERNEL_2_HIGH   0x03ff
after thinking about it I decided to synthesize 4 calculation modules in parallel. So I added the following "pragma" directive to my port:
#pragma HLS array_partition variable=kernel cyclic factor=108
where each kernel has 27 values, so to have access to all the elements I made 27*4= 108. I would like to know how to deposit my data and which address corresponds to what?
my first idea is that:
at the 0x100 : i have 4 byte : byte 0 = value 0 from kernel 0
byte 1 = value 0 from kernel 4
byte 2 = value 0 from kernel 8
byte 3 = value 0 from kernel 12
at the 0x104 : i have 4 bye : byte 0 = value 0 from kernel 16
but it doesn't work the way I want. It works for all 27 kernel values from 0 to 3 (byte 0 of addresses 0x100 0x200 0x300 ... 0x6x00).
but when I write in the byte 1 of the address 0x100 for example it is the kernel 5 which receives the value and not the 4 ?
the instruction I use in python :
conv_kernel.write(0x200, 0x100) #example where I write 1 in byte 1
adel_chaker
after rereading my python excuter code I discovered a small problem of synchronization between the data of the instantiated modules. I was able to solve it.
and so what I thought I understood about the layout of the data in the BRAM was quite correct.
now I find a new problem in creating an output array with the "Xlnk" library, the command: "output_buffer = xlnk.cma_array(shape=(out_size,), dtype=np.uint64)" returns me: "Failed to allocate Memory!" I read that it was the defined size (too big) for Linux and so I had to edit the img file. am I on the right track?
Anyway, thanks again @u4223374 for your help.
