09-16-2019 05:17 AM
HOG function in xfOpenCV library documentation says that output format descriptor must be XF_32UC1 (32 bits unsigned). Also, that output feature vector will be in the fixed point type Q0.16. How should I interpret this information, if they are talking about the same output vector?
Anyone has worked with the output vector of the HOG function? I am trying to link this output with python scikit-image library for pedestrian detection, but I can´t understand how to handle the output. Thanks.
09-20-2019 03:02 AM - edited 09-20-2019 03:03 AM
Hi @kiniman_2000 ,
Safely use the 32 bits unsigned data type 'XF_32UC1' for the output vector. You can refer to the test beach to see that the data is loaded using OpenCV function and transfer into xf:Mat class, then perform the hog_descriptor_accel function. The XF_INPUT_TYPE was defined in the xf_types.h.
Also, The feature vector will be in the fixed point type Q0.16 in the HLS implementation which don't inpact how you manage your code on the high level. Some of the Function Parameter in xfopencv uses the Q format which will be clearly declared in UG1233.
hop function
void hog_descriptor_accel(xf::Mat<XF_INPUT_TYPE, XF_HEIGHT, XF_WIDTH, XF_NPPC1> &inMat, xf::Mat<XF_32UC1, 1, XF_DESC_SIZE, XF_NPPC1> &outMat) { xf::HOGDescriptor <XF_WIN_HEIGHT,XF_WIN_WIDTH,XF_WIN_STRIDE,XF_BLOCK_HEIGHT,XF_BLOCK_WIDTH,XF_CELL_HEIGHT,XF_CELL_WIDTH, XF_NO_OF_BINS,XF_DESC_SIZE,XF_INPUT_COLOR,XF_OUTPUT_MODE,XF_INPUT_TYPE,XF_32UC1,XF_HEIGHT,XF_WIDTH,XF_NPPC1,XF_USE_URAM>(inMat,outMat); }
Test bench
////////////////// HLS TOP Function Call ////////////////////////
static xf::Mat<XF_INPUT_TYPE, XF_HEIGHT, XF_WIDTH, XF_NPPC1> inMat(img.rows,img.cols);
inMat.copyTo(img.data);
#if REPETITIVE_BLOCKS
static xf::Mat<XF_32UC1, 1, XF_DESC_SIZE, XF_NPPC1> outMat(1,dim_rb);
#elif NON_REPETITIVE_BLOCKS
static xf::Mat<XF_32UC1, 1, XF_DESC_SIZE, XF_NPPC1> outMat(1,dim_nrb);
hog_descriptor_accel(inMat,outMat);
#endif
Sorry for the delay of the respond.
Wen
**~ Got a minute? Answer our Vitis HLS survey here! ~**
10-01-2019 03:43 AM
Do you have any update on this?
01-02-2020 07:10 AM - edited 01-02-2020 07:12 AM
Hi, I'm confused about this code in testbench:
#if REPETITIVE_BLOCKS int dim_rb = (total_no_of_windows*XF_NODPW)>>1; int no_of_descs = dim_rb; #elif NON_REPETITIVE_BLOCKS int dim_nrb = (nohb_tb*novb_tb*XF_NOBPB)>>1; int no_of_descs = dim_nrb;
Why ">>1"?
I guess maybe the output of hog_descriptor_accel is organized as two Q0.16 combined into one ap_uint32_t, as I see both REPETITIVE_BLOCKS and NON_REPETITIVE_BLOCKS convert ap_uint32_t to two number:
#elif REPETITIVE_BLOCKS OUT_T1* output1 = (OUT_T1*)malloc(dim * sizeof(OUT_T1)); ap_uint32_t temp; int high=15,low=0; int cnt=0; for(int i=0;i<(dim_rb);i++) { temp=outMat.read(i); high=15;low=0; for(int j=0;j<2;j++) { output1[i*2+j]=temp.range(high,low); high+=16; low+=16; cnt++; } }
#elif NON_REPETITIVE_BLOCKS // Reading in the NRB mode and arranging the data for comparison float out_fl_tmp[dim_expand]; int tmp_cnt=0; for(int i = 0; i < dim_nrb; i++) { for(int j=0;j<2;j++) { out_fl_tmp[((i<<1)+j)] = (float)((output[i]>>(j<<4))&operatorAND)/(float)65536.0; } }
that makes the number of dimension should be ">>1".
