2017.1 VIVADO crash
Hi, there
I use VIVADO 2017.1 to synthesize the design for VU440. The implementation report the following error message.
Abnormal program termination (11)
Please check '/users/pchen/T0/vu440/0914_4374/vivado_project/vu440_1ch_0914_4374.runs/impl_1/hs_err_pid19159.log' for details
The synth and impl runme.log and 19159.log are attached. Please check it. thanks
Ping Chen
2018.9.15
Re: 2017.1 VIVADO crash
@chenpingx
Is it possible for you to test in the latest vivado release i.e 2018.2? It is not expected from the tool to crash but always give an error or proper information message to use if there is any design issue.
https://www.xilinx.com/support/answers/55854.html
If the issue exists in 2018.2 then please share the dcp so that we can reproduce it our end and forward it to Factory to get it fixed.
With 2017.1, you can continue with the workaround of using Default strategy which you mentioned is not crashing.
--Syed
Hi @chenpingx,
This is implementation issue and needs to be transferred to impl. board.
Tool is crashing in post place phys_opt_design phase.
1. Which OS version are you using for Vivado 2017.1?
2. Can you try to run full implementation with default strategy and check?
If second point does not help than can you provide your post synth dcp to evaluate ?
hemangd
hemangd
Please check my comments for the question.
From Ping: Linux
VIVADO crash again. Please check attached log. thanks
Piing Chen
2018.9.17
Hi @chenpingx. Is a reproducible DCP available to attach? I did not find a matching reported issue from 2017.1. I can also send a private message to set up an alternative method of sending the DCP if preferred.
No. it is for sure VU440 will crash or stop working with PerformanceExtraOpt implementation setting.
regards
Ping Chen
2018.9.23
@chenpingx
--Syed
The default implementation is OK for 2017.1. But, the 2018.2 fail to synthesize the ARM DAP design. I could not move to 2018.2 VIVADO. You can check the following link for detailed information. thanks
Ping Chen
2018.9.23
https://forums.xilinx.com/t5/Synthesis/FSM-extraction-for-2017-1-and-2018-1/td-p/875704
Hi @chenpingx. There is not much help that can be provided if this issue has not been reported, and a reproducible DCP is not available.
If other directives besides PerformanceExtraOpt are successful, these would be a viable workaround.
got it. Now, the default implementation is working. I will discuss with my boss about providing the DCP. So, close this thread firstly. thanks
Ping Chen
2018.9.28
