Voyager
Voyager
[2019.2] [DRC RTSTAT-1] Unrouted nets: 1 net(s) are unrouted. The problem bus(es) and/or net(s) are design_1_i/oddr_0/inst/clk_out.
I am trying to drive a differential clock signal out from the FPGA. Following this post I decided to put an ODDR before the OBUF_DS as shown below:
But this kind of design implementation ends up with the following errors:
[DRC RTSTAT-2] Partially routed nets: 1 net(s) are partially routed. The problem bus(es) and/or net(s) are design_1_i/oddr_0/inst/clk_out_BUFGCE.
What could be the reason that  makes Vivado to do not route the net oddr_0/inst/clk_out ?
s.
Re: [2019.2] [DRC RTSTAT-1] Unrouted nets: 1 net(s) are unrouted. The problem bus(es) and/or net(s) are design_1_i/oddr_0/inst/clk_out.
There is another line from the oddr clk_out port.  Where does it go?  The oddr output should only go to an I/O buffer.
Voyager
Voyager
@bruce_karaffayou are right.
I was feeding also other IPs clock input with ODDR output, and this was generating troubles.
Thanks for ensuring.
s.
