Observer davidhuo
A Erorr when use fpga_edline to change iodelay_value
device: v6x760
ise: 14.5
rtl:
IODELAYE1 #(
  .CINVCTRL_SEL ("FALSE"),
 .DELAY_SRC        ("I"),
 .IDELAY_TYPE      ("FIXED"),
.IDELAY_VALUE   (31),
.ODELAY_TPYE   (FIXED"),
.ODELAY_VALUE   (0),
.REFCLK_PREQUENCY(208.0),
.SIGNAL_PATTERN ("CLOCK")
IODELAY_DQS(
  .C (1'b0),
 .CINVCTRL (1'b0),
 .CLKIN (1'b0),
 .ODATAIN(1'b0),
 .DATAIN (1'b0),
 .IDATAIN(emdqs[0]),
 .DATAOUT(pad_in_dmc_dqs[0]),
 .CNTVALUEIN(5'h0),
 .CNTVALUEOUT(),
 .CE(1'b0),
 .INC(1'b0),
 .RST(1'b1),
 .T(1'b1)
Now I want to use fpga_edline to edit *.ncd file to change the IDELAY_VALUE
setattr comp dqs_iodelay[0].IODELAY_DQS config "......IDELAY_VALUE:2....."  # other paramters not change
I got several  drc errors, the pins of  the IODELAY are not connectivity(CNTVALUEOUT[4:0], T,ODATAIN,etc)
1. why this happen ?
2. How to do next ?
Re: A Erorr when use fpga_edline to change iodelay_value
Try running the "trim" command on the component you edited as documented in this AR:
http://www.xilinx.com/support/answers/21667.htm
