A PAR challenge for tri-states
I am trying to produce a hardware which needs speed and accuracy in timing. I will sum up the problem with a code.
if rising_edge(clk) then
   if wea = '1' then
      douta <= some_signal(15 downto 8);
   else
      douta <= (others => 'Z');
   end if;
   if web = '1' then
      doutb <= some_signal(7 downto 0);
   else
      doutb <= (others => 'Z');
   end if;
end if;
Here "wea" and "web" are generated from the same signal and they are at the same level but for speed purpose I am using "equiavlent_register_removal = NO" attribute for these signals. Also again for speed douta, doutb signals have the "IOB = TRUE" attribute.
Problem is when I use FPGA editor the tri-state enable bits for "douta" port are directly in the IOB cell, which is the thing I want
but when I observe the tri-state enable bit for the "doutb" port it is not in the IOB cell, besides it is far away from the IOB so there is a 2 ns delay between douta and doutb ports.
Although I am using the same kind of signals why this happens? Any ideas?
By the way I use ISE 9.2.04 and a virtex4 LX100.
Historian
Historian
Re: A PAR challenge for tri-states
eneserdin wrote:
   if wea = '1' then
   else
   end if;
   if web = '1' then
   else
   end if;
end if;
The tristate assignment should NOT be part of a synchronous process.
-a
I only wonder. Why tristate assignment should NOT be a part of synchronous process? Is this a design rule or a drawback in terms of resource usage or something else?
Thanks in advance.
Enes.
Historian
Historian
Thanks in advance.
Enes.
THINK HARDWARE. What output would you expect to see if the input to a real flip-flop was tristated?
-a
Yes you are right doing it combinatorial is the best. But XST is handling this kind of operation, I think, such that it is creating tristate enables for the output buffer. Since I use IOB property it puts the enable flip-flop just next to the IOB cell.
By the way for the problem I wrote I found a solution such that I am creating an enable signal bus as the same width as the output port and using it bit by bit.
Thank you for the valuable information.
Enes
