Hamidshafaghi
AES encryption IP core
Hi my friends
I need to use the AES-256 encryption algorithm in PL part of zynq-7000 SOC.
How i can add this AES-256 IP core to my vivado project ?
This IP core did not exist in vivado software .
The link below explains this, but I did not understand how it added IP core to the project !
https://www.xilinx.com/support/documentation/ip_documentation/aes/v1_1/pg383-aes.pdf
Please help me
thanks
Tags (3)
syedz
@Hamidshafaghi
Which vivado version & device are you using? The IP is supported from Vivado 2020.1and with limited devices:
https://www.xilinx.com/products/intellectual-property/ef-di-aes/ef-di-aes-software-requirements.html
 Home page: https://www.xilinx.com/products/intellectual-property/ef-di-aes.html
Also, You will need a license to use this IP: https://www.xilinx.com/support/documentation/ip_documentation/aes/v1_1/pg383-aes.pdf#page=7
--Syed
syedz
@Hamidshafaghi
--Syed
gavinerryairbus
Hello
I was thinking about this IP for a new project.  For some reason it seems to be missing in v2021.1  The files are in C:\Xilinx\Vivado\2020.2\data\ip\xilinx\aes_v1_1 but the corresponding files are missing (there is no C:\Xilinx\Vivado\2021.1\data\ip\xilinx\aes... folder)  Perhaps a packaging error?
Gavin
Hamidshafaghi
Thank you
This IP core is for version 2021.1 and ZYNQ-Ultera Scale+.
