Actual Ratio
what is mean the actual ratio = 30%
is a percentage  from the total number of slices on that FPGA (vertix 7)?
and what is the difference between
Slices
Logic Cells
CLB Flip-Flops
thank you in advance
Without some context, it's not clear what your "actual ratio" question is about. Here is a document that will help you understand more about CLBs:
http://www.xilinx.com/support/documentation/user_guides/ug474_7Series_CLB.pdf
