Allow Combinatorial Loops
Hi!
I have to implement a combinatorial loop (in a ring oscillator).
While implementing the design in vivado I get the error
"ERROR: [DRC LUTLP-1] Combinatorial Loop Alert: 733 LUT cells form a combinatorial loop. This can create a race condition. Timing analysis may not be accurate. The preferred resolution is to modify the design to remove combinatorial logic loops. If the loop is known and understood, this DRC can be bypassed by acknowledging the condition and setting the following XDC constraint on any one of the nets in the loop: 'set_property ALLOW_COMBINATORIAL_LOOPS TRUE [get_nets <myHier/myNet>]'. One net in the loop is INTERCON[732]. Please evaluate your design. The cells in the loop are: ... "
Therefor I added the suggested line to my xdc-file:
set_property ALLOW_COMBINATORIAL_LOOPS true [get_nets INTERCON[732]];
However, I still get the ERROR and it seems that vivado is simply ignoring the constraint.
Any ideas?
I've now tried a different thing, namely
attribute DONT_TOUCH : string;
attribute DONT_TOUCH of INTERCON : signal is "TRUE";
attribute ALLOW_COMBINATORIAL_LOOPS : string;
attribute ALLOW_COMBINATORIAL_LOOPS of INTERCON : signal is "TRUE";
and this actually seems to work (which I didn't expect to be honest).
I'll keep you posted!
jmcclusk
Mentor
Mentor
It's likely that the [get_nets  xxxx] is not actually finding the net as needed.  The way I would attack this is to attach the attribute to the net directly in the RTL, along with a DONT_TOUCH attribute.   Vivado synthesis will frequently "optimize" away or otherwise mangle combinatorial loops.
Another tip for a ring oscillator..   They have a tendency to oscillate in unstable overtone modes unless you introduce some low pass filtering by using a majority gate with staggered (different taps on the delay line) inputs.    I've been thinking it's time to write and post a solid VHDL implementation for ring oscillators, because this subject comes up so frequently on the boards.
Thank you!
I'm not exactly sure, what you mean with "directly in the RTL".
You mean in my .vhdl file directly? Could you tell me the syntax for that?
I do have a DONT_TOUCH attribute in place already though.
jmcclusk
Mentor
Mentor
Now that I think about it, I realize that I have to test this theory about putting the property in the RTL.  It might not work.
In the meantime,  here is how to get it working in Vivado.   It's been solved by @misdarvishi :
https://forums.xilinx.com/t5/Implementation/How-to-apply-set-property-ALLOW-COMBINATORIAL-LOOPS-TRUE-to-pass/td-p/779026
Actually I've read that post already but didn't refer to it as helpfull as this code is placed in .xdc too, right?
I'll try that anyway.
jmcclusk
Mentor
Mentor
@david.radakovits
you are officially awesome.     Kudos!
Now close the thread by accepting your post above as a solution.   Congratulations!
drjohnsmith
ring oscilators, a very often covered topic
these are the two gods of xilinx, austin and ken,
https://forums.xilinx.com/t5/7-Series-FPGAs/How-to-implement-a-ring-oscillator-with-routings-of-FPGA-Where/td-p/768444
alesea
And...
Neither Ken, nor I are part of Xilinx.  Ken is retired and I am off to new challenges,
Austin Lesea
pintu05eee
I have seen that you have found the solution. I am facing the same issue and tried to solve using your guideline. Here i am sharing details. Can you please check and share the commands which I need to put in xdc file.
ERROR:
[DRC LUTLP-1] Combinatorial Loop Alert: 1 LUT cells form a combinatorial loop. This can create a race condition. Timing analysis may not be accurate. The preferred resolution is to modify the design to remove combinatorial logic loops. If the loop is known and understood, this DRC can be bypassed by acknowledging the condition and setting the following XDC constraint on any one of the nets in the loop: 'set_property ALLOW_COMBINATORIAL_LOOPS TRUE [get_nets <myHier/myNet>]'. One net in the loop is ro1/RO1_a1/in2. Please evaluate your design. The cells in the loop are: ro1/RO1_a1/in2_INST_0.
Solution that I have tried:
attribute DONT_TOUCH of ro1/RO1_a1/in2 : signal is "TRUE";
attribute ALLOW_COMBINATORIAL_LOOPS of ro1/RO1_a1/in2 : signal is "TRUE";
and
attribute DONT_TOUCH of in2 : signal is "TRUE";
attribute ALLOW_COMBINATORIAL_LOOPS of in2 : signal is "TRUE";
