Visitor martinez.r
Artix 7 Nexys 4 Vivado error
Hello, I am tring to syntesize a class project and continuously get an error that my simple test project has failed to synthesize. The professor seems to think that it is an issue with Vivado itself, which I don't really know what to do with. Attatched are both the PDF for the assignment, which is very basic, as well as my project folder archived as a .zip.
Can someone please shed some light on this, or point me in the right direction?
Rob
Re: Artix 7 Nexys 4 Vivado error
Hi @martinez.r,
Basically, you have not set the IO standarads for your IOs and that's what the error says about.
Go through these AR below which may help you out.
https://www.xilinx.com/support/answers/56354.html
Add IOSTANDARD and PACKAGE_PIN constraints for all I/Os in the design. - Open implemented design and set the IO Standard as per your requirement on the IOs.
hemangd
Hi @martinez.r,
hemangd
Visitor martinez.r
Thank you @hemangd
that was exactly the problem!
