Anonymous
Not applicable
BRAM extra large - 128bit wide worked, how broad may one go?
The BRAM works wonders on the ARTIX-7 using 128 bits wide at 400 MHz seemed allright
For to have faster RAM access its better to have it very broad I noticed and I am thinking if I should try push it to 256 or 512?
Any advice on the issues I may encounter its going to run at 125MHz
Anyone done some experimenting on that and can share its views?
Re: BRAM extra large - 128bit wide worked, how broad may one go?
@Anonymous I once made a 88 wide 32 bit (ie ~2800 bits total) entry parallel vector file from BRAMs and it worked quite well.  Basically each BRAM is 72 bits long (512 deep and writable at 9 bit byte granularity) and there is technically no limit on how many of these you can read/write in parallel.  It might be challenging to implement but it is possible to access all BRAMs in a chip at the same cycle with good design.
Anonymous
Not applicable
its real good I posted I was wondering what step to go, I realise I can proceed to broader, real amazing.
