05-28-2020 08:42 AM
I am using "ISE Project Navigator," and get warning in "Implement Design."
It occures in "Fit." as shown in a figure attached.
WARNING:Cpld - Unable to retrieve the path to the iSE Project Repository. Will
use the default filename of 'test_led.ise'.
My 3rd party board is not listed in "Design Propertiies."
And Package is also not listed, my chip is VQG44AMS1845.
Design Propertiies
I set "Design Propertiies" as below.
E.D.Board: None Specified
Family: CoolRunner2 CPLDs
Device: XC2C64A
Package: VQ44
Could anybody please show me a solution?
Can one use original board? And how?
Thank you.
05-29-2020 06:27 AM
Hi @2U3 ,
Which ISE version you are targetting?
In ISE 10.x, the .ise file was passed in the command line in order to specify the location of the generated constraints database. The use of the .ise file on the command line was obsoleted in the ISE 11.1 software revision. However, cpldfit was not updated accordingly and still looks for the .ise file even though one does not exist and constraints are passed to the design during the Translate process.
This warning can be safely ignored if you are using ISE 11.x or above.
Raj
05-29-2020 06:27 AM
Hi @2U3 ,
Raj
05-29-2020 08:30 AM
Hi Raj,
I am using 14.7, and would ignore the warning to go ahead.
Thank you.
2U3
