Participant kwiatlab
Can you specifiy a subset of pins to assign to, and have the tools choose from those?
I have an FPGA evaluation board and have made an expansion board for an application that accesses 32 I/O pins, or 16 differential pairs. Currently I hardcode the locations into my .UCF for each pin, but I am realizing that the way in which I have chosen them may not be ideal. Looking through the constraints guide I cannot find a command for which I can specify a subset of pins, and then have the tools only consider them.
For example say I have four possible I/O pins, AB1, AB2, AB3, and AB4 and internally have four data pins D1, D2, D3, D4. How can I have the tools choose the best possible routing for these data pins, but only consider the four AB pins above?
Professor
Professor
Re: Can you specifiy a subset of pins to assign to, and have the tools choose from those?
First, I'll say that there is at least one way to do what you're asking, but it's not clear that you'll get any benefit from it.  Your assumption is that the tools are better than you are at selecting IO sites for your design, while I've rarely found that to be the case.  But if you want to try it:
Method 1)
LOC or PROHIBIT all the other pins of the chip.  LOC pins that are fixed in your board design.  PROHIBIT any other pins to prevent them from being chosen for top level signals that haven't already been LOCed.  You already know the LOC syntax.  Check the Constraints Guide for the PROHIBIT syntax.
Method 2)
Use LOCATE rather than LOC to map a module to a site group.  This is described in the constraints guide with the usual style of "example" that makes little sense unless you already grasp the concept.  i.e. the "examples" are more like a BNF definition of the syntax and would create errors if you pasted them into a design.  If you can figure out how to use this method, you'll get kudos for posting your UCF here.
-- Gabor
Historian
Historian
You should ALWAYS lock down the pin assignments. Your PCB doesn't change, therefore neither can your pin assignments.
Ah let me clarify. My PCB also has 16 inputs, which come from an external board, so I am able to change the assignment of the inputs as I need to.
More specifically, I have a 16-channel 10 GHz demultiplexer evaluation board with 32-SMA outputs. These go to a PCB that I have made, which takes these 32-SMA outputs and routes them into the Samtec interface my FPGA evaluation board has. So, I have the freedom to change around the SMA cables out of the DMUX to suit my needs.
Historian
Historian
Well, you need to know which input is used, right? And you can't change the assignment after configuration; indeed, you can't change it after place and route!
So again, ALWAYS lock down your pin assignments.
Professor
Professor
Method 1)
Method 2)
-- Gabor
The UCF constraint syntax supports LOC constraints with a comma seperated list of values. I'm not certain it works with I/O pins but it very well might.
LOCATE is a PCF constraint that's not normally used as an input source to map. It can be done but it complicates the flow. Make sure that the user constraint is outside the Schematic Start/Schematic End defined area or it will be overritten by map.
