cvasselin
Cannot generate bitstream
I use Vivado 2017.4; When I run Synthesis and Implementation everything seems ok.
But when I want to generate the bitstream file nothing happens with no error messages.
There is no bitstream file in the .runs/impl_l directory as expected.; only some .tcl .sh .xml files..
cvasselin
I've done the reset and now It's works now !
Thank you very much !
Best regards,
hj
Can you share the vivado log? It might give us a clue.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
cvasselin
You wil find attached the TCL console logs that I've got when I launched the project and made a synthesis, implementation and try to generate bitstream.
I have no others logs form logs screen or messages.
Best regards,
syedz
@cvasselin,
Can you reset the synthesis run and try running the complete flow again? The log file shared in your previous post doesn't provide much information. Right click on Run Synthesis and select Reset Synthesis run as shown in below image:
Share the runme.log file which will be present in <project>/<project>.runs/impl_1/runme.log.
Also how long did you wait to confirm that bit file is not generated.
--Syed
cvasselin
Best regards,
