debugger
Constraining logic to specific PBLOCKs
I want to constrain some logic to a specific area with a PBLOCK. After implementation I see that the logic is not entirely placed inside the PBLOCK perimeter. Vivado place it in the vicinity of the PBLOCK with some of the logic placed inside and outside. This is happen even if I resize or move the PBLCK to fit the logic.
Anybody know how to fix this?
Many thanks!
hongh
Please  try to set the IS_SOFT property to 0 for the pblock.
Ex: set_property   IS_SOFT 0 [get_pblocks XX]
hongh
debugger
Thank you! It worked.
Cheers
